About This File
Features:
- Places books in a row using different types of chaotic or not-so-chaotic arrays
- Eliminates books that are too tall or wide for the box
- Allows to randomize the sequence of placement within each book collection
- Option to repeat the list to fill long shelves
- Six different types of random angles or all straight
- Offset from shelf edge (Random Max/Min)
- Allows for any number of stacks in-between standing books
- Number of books per stack (Random Max/Min)
- Offset and angles for stacked books (Random Max/Min)
- Option to have only stacks, no upright books
Known Issues:
- The gap between angled books and stacks is not correct. I won't fix it 🙂
IMPORTANT
*** Configure your books using the Marionette instance provided in the document. Then, make a copy. Ungroup that copy to lock its values. Start over. This will speed up your workflow considerably and you won't have to wait for each Marionette instance to recompile ***
What's New in Version 2.2 See changelog
Released
- Fixed a problem with the 'Hardcover' library where the shelf cage had to be 2000mm deep x 2000mm tall for any books to be shown
- Converted to run with VWX 2019
- v 2.2 has the gloss fixed for the textures. They should now render more realistically.
