About This File
This node imports a resource based on the type into the active document and returns this object.
With the input FolderName a folder can be defined where the resource will be placed.
If this input is left empty, the resource will be placed at the top level of the resource manager.
General:
If the resource to be imported is already present in the document but modified, the usual dialog with change/overwrite, etc., will appear.
It is not necessary to have the reference as a favorite or anything like that. The absolute path is specified.
It is not possible to work with %userprofile% or %AppData%.
Here is the documentation for the resource typs:
some of the common resource type numbers:
Symbol: 16
Worksheet: 18
Record Format: 47
Hatch: 68
Line Type: 93
Texture: 97
ATTENTION!!!
As is usual in Vectorworks, there must be no duplicate names.
The node does not provide feedback if the folder name already exists. The folder will simply not be created if the name already exists.
This does not have to be another folder. If there is a class/symbol or something similar with the same name, the folder will not be created.
Edited by Zuzzla
What's New in Version 1.0.0 See changelog
Released
No changelog available for this version.
