About This File
This file contains a Marionette network that converts 2D polys into Massing Models. It reads the Record Format info attached to the poly and uses that information to create the Massing Model. It also transfers all attached Records to the Massing Model. This network is useful for converting shapefile data into Massing Models. To use the network, select the wrapper and make sure that all the fields in the Object Info palette correspond correctly to the objects that you want to convert. All of the info that you want to use to create the Massing Model must be in a single record, but all attached records will be transferred over by the script.
Also included in the file is a worksheet that allows you to calculate Floor Usage Data for each floor of a multistory building. If you have one type of usage on the first floor, and a different type of usage on the upper floors, you can calculate that in the worksheet. (If you have more than two types of usage, it can only calculate the first two types.) To change the usage type in the worksheet, just type the name of the usage type, like "Retail" or "Residential" into the top row of one of the Area by Usage Type Columns. The lower rows will adjust appropriately.
What's New in Version 1.0.0 See changelog
Released
No changelog available for this version.
