Value Function
2D Lintel Visibility Class =('Door'.'CeilingMainClass')
2D Loci Visibility Class =('Door'.'NonPlotClass')
2D Overhead Swing Visibility Class =('Door'.'CeilOvrhdClass')
2D Slab/Swing Visibility Class =('Door'.'SlabSwingClass')
3D Tag Horizontal Offset =('Door'.'Tag3DHorzOffset')
3D Tag Vertical Offset =('Door'.'Tag3DVertOffset')
Accessories =('Door'.'Accessories')
Astragal Flange =('Door'.'AstragalWidth')
Astragal Thickness =('Door'.'AstragalDepth')
Bottom Rail Width =('Door'.'BottomStileWidth')
Configuration =('Door'.'Config')
Detail Level =('Door'.'DetailLevel')
Door Finish =('Door'.'DoorFinish')
Door Fire Rating =('Door'.'DoorFR')
Door Material =('Door'.'DoorMaterial')
Door Sill =('Door'.'DoorSill')
Draw Wall Lines =('Door'.'DrawWallLines')
Exterior Jamb Class =('Door'.'ExtJambClass')
Exterior Lintel Protrusion =('Door'.'ExtLintelProt')
Exterior Panel Class =('Door'.'ExtPanelClass')
Exterior Rails Class =('Door'.'ExtSRClass')
Exterior Sash Class =('Door'.'ExtSashClass')
Exterior Splay Angle =('Door'.'ExtSplayAngle')
Exterior Splay Depth =('Door'.'ExtSplayDepth')
Exterior Splay Diagonal =('Door'.'ExtSplayDiag')
Exterior Splay Width =('Door'.'ExtSplayWidth')
Exterior Threshold Depth =('Door'.'ExtTHDepth')
Exterior Trim Class =('Door'.'ExtTrimClass')
Exterior Trim Thickness =('Door'.'ExtTrimDepth')
Exterior Trim Width =('Door'.'ExtTrimWidth')
Exterior Wall Components =('Door'.'NumExtComps')
Frame Finish =('Door'.'FrameFinish')
Frame Fire Rating =('Door'.'FrameFR')
Frame Material =('Door'.'FrameMaterial')
Frame Type =('Door'.'FrameType')
Glazing Class =('Door'.'GlazingClass')
Hardware Closer Type =('Door'.'HWCloserType')
Hardware Description =('Door'.'HWDesc')
Hardware Key Code =('Door'.'HWKeyCode')
Hardware Lock Type =('Door'.'HWLockType')
Hardware Note =('Door'.'HWNotes')
Hardware Quantity =('Door'.'HWQty')
Hardware Set ID =('Door'.'HWSetID')
Hardware Stop Type =('Door'.'HWStopType')
Hardware Symbol Name =('Door'.'HWSymName')
Hardware Type =('Door'.'HWType')
Head Detail =('Door'.'HeadDetail')
Height =('Door'.'Height')
Hinge Marker Class =('Door'.'HingeClass')
Horizontal Leaf Panels =('Door'.'NumPanelsH')
ID Label =('Door'.'IDLabel')
ID Label Class =('Door'.'IDLabelClass')
ID Label Shape =('Door'.'IDLabelShape')
ID Label Size =('Door'.'IDLabelSize')
ID Prefix =('Door'.'IDPrefix')
ID Suffix =('Door'.'IDSuffix')
Include Exterior Trim =('Door'.'ExtTrim')
Include Hardware =('Door'.'IncludeHardware')
Include Interior Trim =('Door'.'IntTrim')
Include Lintel =('Door'.'Lintel')
Include Sidelight Muntins =('Door'.'Muntins')
Include Sidelights =('Door'.'SideLights')
Include Threshold =('Door'.'Threshold')
Interior Jamb Class =('Door'.'IntJambClass')
Interior Lintel Protrusion =('Door'.'IntLintelProt')
Interior Panel Class =('Door'.'IntPanelClass')
Interior Rails Class =('Door'.'IntSRClass')
Interior Sash Class =('Door'.'IntSashClass')
Interior Splay Angle =('Door'.'IntSplayAngle')
Interior Splay Depth =('Door'.'IntSplayDepth')
Interior Splay Diagonal =('Door'.'IntSplayDiag')
Interior Splay Width =('Door'.'IntSplayWidth')
Interior Threshold Depth =('Door'.'IntTHDepth')
Interior Trim Class =('Door'.'IntTrimClass')
Interior Trim Thickness =('Door'.'IntTrimDepth')
Interior Trim Width =('Door'.'IntTrimWidth')
Interior Wall Components =('Door'.'NumIntComps')
Jamb Depth =('Door'.'JambDepth')
Jamb Detail =('Door'.'JambDetail')
Jamb Extension Width =('Door'.'JambExtenWidth')
Jamb Width =('Door'.'JambWidth')
Keep ID Horizontal =('Door'.'KeepIDHoriz')
Leaf Height (Read Only) =('Door'.'DoorHeight')
Leaf Horizontal Muntins =('Door'.'DoorHMuntins')
Leaf Muntin Bar Depth =('Door'.'GLMuntinDepth')
Leaf Muntin Bar Offset =('Door'.'GLMuntinOffset')
Leaf Muntin Bar Width =('Door'.'DoorMuntinWidth')
Leaf Muntin Style =('Door'.'MuntinStyle')
Leaf Thickness =('Door'.'DoorThickness')
Leaf Type =('Door'.'LeafType')
Leaf Vertical Muntins =('Door'.'DoorVMuntins')
Leaf Width (Read Only) =('Door'.'DoorWidth')
Left Sidelight Width =('Door'.'LeftLiteWidth')
Left/Right Stile Width =('Door'.'LRStileWidth')
Lintel Angle =('Door'.'LintelAngle')
Lintel Class =('Door'.'LintelClass')
Lintel Drop =('Door'.'LintelDrop')
Lintel Thickness =('Door'.'LintelThick')
Lintel Type =('Door'.'LintelType')
Location =('Door'.'Location')
Manufacturer =('Door'.'Manuf')
Masonry Module =('Door'.'MasonMod')
Masonry Opening Height (Read Only) =('Door'.'MOHeight')
Masonry Opening Width (Read Only) =('Door'.'MOWidth')
Mid Stile Width =('Door'.'MidStileWidth')
Model =('Door'.'Model')
Mullion Depth =('Door'.'TranMullDepth')
Mullion Width =('Door'.'TranMullWidth')
Net Glazed Area-Squared (Read Only) =('Door'.'NGA2')
Notes =('Door'.'Notes')
Offset In Wall =('Door'.'OffsetInWall')
On Schedule =('Door'.'OnSched')
Open Angle =('Door'.'OpenAngle')
Operation =('Door'.'Operation')
Overall Threshold Depth =('Door'.'OverallTHDepth')
Plan Detail =('Door'.'PlanDetail')
Right Sidelight Width =('Door'.'RightLiteWidth')
Rise =('Door'.'Rise')
Rough Opening Height (Read Only) =('Door'.'ROHeight')
Rough Opening Width (Read Only) =('Door'.'ROWidth')
Set Top Panel Height =('Door'.'SetTopPanel')
Shim Gap =('Door'.'ShimGap')
Show 3D Open =('Door'.'3DOpen')
Show Exterior Hinge Marker =('Door'.'Show3DHinge')
Show ID Leader =('Door'.'ShowIDLeader')
Show Interior Hinge Marker ='.'ShowInteriorHinge')
Show Shim Gap in Plan =('Door'.'ShowShimGap')
Show Tag in 3D =('Door'.'TagInElevation')
Sidelight Glazing Class =('Door'.'SideLGlazingClass')
Sidelight Horizontal Muntins =('Door'.'NumHMuntins')
Sidelight Mullion Depth =('Door'.'SLMullDepth')
Sidelight Mullion Width =('Door'.'SLMullWidth')
Sidelight Muntin Bar Depth =('Door'.'SLMuntinDepth')
Sidelight Muntin Bar Offset =('Door'.'SLMuntinOffset')
Sidelight Muntin Bar Width =('Door'.'MuntinWidth')
Sidelight Muntin Style =('Door'.'GlassMuntin')
Sidelight Sash Depth =('Door'.'SashDepth')
Sidelight Sash Width =('Door'.'SashWidth')
Sidelight Vertical Muntins =('Door'.'NumVMuntins')
Size Reference =('Door'.'SizeReference')
Splay Exterior Wall =('Door'.'ExtSplay')
Splay Interior Wall =('Door'.'IntSplay')
Spring =('Door'.'Spring')
Stock No. =('Door'.'SKU')
Symbol Name =('Door'.'SymbolName')
Threshold Class =('Door'.'ThresholdClass')
Threshold Detail =('Door'.'ThreshDetail')
Threshold Extension =('Door'.'ThresholdExt')
Threshold Nose =('Door'.'ThreshNose')
Threshold Offset =('Door'.'OffJambCenter')
Threshold Thickness =('Door'.'ThreshThick')
Threshold Under Leaf Only =('Door'.'ThreshUnderLeaf')
Top Panel Height =('Door'.'TopPanelHeight')
Top Rail Width =('Door'.'TopStileWidth')
Top Shape =('Door'.'TopShape')
Transom =('Door'.'Transom')
Transom Glazing Class =('Door'.'TransomGlazingClass')
Transom Horizontal Muntins =('Door'.'HTranMntn')
Transom Muntin Bar Depth =('Door'.'TransMuntinDepth')
Transom Muntin Bar Offset =('Door'.'TranMntnOffset')
Transom Muntin Bar Width =('Door'.'TranMntnBWidth')
Transom Muntin Style =('Door'.'TranMntnStyle')
Transom Muntins =('Door'.'TranMuntins')
Transom Sash Depth =('Door'.'TranSashDepth')
Transom Sash Width =('Door'.'TranSashWidth')
Transom Vertical Muntins =('Door'.'VTranMntn')
Unequal Leaf =('Door'.'UnequalLeaf')
Use Exterior Splay Angle =('Door'.'UseExtSplayAngle')
Use Exterior Splay Width =('Door'.'UseExtSplayWidth')
Use Interior Splay Angle =('Door'.'UseIntSplayAngle')
Use Interior Splay Width =('Door'.'UseIntSplayWidth')
Use Jamb Extension =('Door'.'UseJambExtension')
Use Lintel Angle =('Door'.'UseLintelAngle')
Use Lintel Drop =('Door'.'UseLintelDrop')
Use Marker on ID Leader =('Door'.'UseMarker')
Use Part Line Styles =('Door'.'LW_LS_OverRide')
Use Symbol Definition =('Door'.'UseSymDef')
Use Wall Depth =('Door'.'UseWallDepth')
User Field 1 =('Door'.'UserFld1')
User Field 2 =('Door'.'UserFld2')
User Field 3 =('Door'.'UserFld3')
User Field 4 =('Door'.'UserFld4')
User Field 5 =('Door'.'UserFld5')
User Field 6 =('Door'.'UserFld6')
User Field 7 =('Door'.'UserFld7')
User Field 8 =('Door'.'UserFld8')
User Field 9 =('Door'.'UserFld9')
User Field 10 =('Door'.'UserFld10')
Vertical Leaf Panels =('Door'.'NumPanelsV')
Width =('Door'.'Width')
Width Leaf 1 =('Door'.'FixedLeafWidth')
Width Leaf 2 (Read Only) =('Door'.'Leaf2Width')
Edited by JimW
Report Article
There are no comments to display.
