When using the Vectorworks Odyssey with Meta Quest, there some technical factors that need to be considered to achieve the best performance and experience the tool can offer. Vectorworks Odyssey is designed to handle files of up to a million triangles and 400-600 while maintaining a consistent frame rate of 72 FPS. Although some restrictions apply, that is generally the limit for a smooth experience.
Please note that this complexity criteria are not directly correlated with the .vwx file size. When a model is exported to. vgx, the number of triangles is decimated, and individual objects are combined to minimize their count. To determine the number of objects and triangles in your project, open the .vgx file in the Vectorworks Cloud Services 3D viewer, either through a web browser or the Nomad app. Then, click on Settings (gear icon) and look for the "Faces" and "Geometry" statistics in the project settings.
For more information, please refer to the link below:
View 3D models of Vectorworks files
For more information on the Meta Quest
performance tests, please refer to this article:
Testing and performance analysis
Please note that a frame rates below 72 FPS may induce nausea in some users.
Report Article
There are no comments to display.
