  • ODBC Driver Information
    PVA - Jim
    The Vectorworks 2011 Design Series products include the ability to communicate with external databases according to Open Database Connectivity (ODBC) standard. Using ODBC, a set of data can be used to automatically update the records attached to objects. Similarly, Vectorworks objects can send object data to a database, updating it.
    When setting up a database program for ODBC functionality, related drivers may not be installed. This list describes drivers available for each platform, where to obtain them, and current problems that may exist.
    Windows
    On Windows, the ODBC manager is integrated into the operating system (OS).
    Driver Name Driver Driver Connection Update VW records by reading data from database Update database with VW record data Add new database table rows through object connection
    Microsoft Access Integrated* in the OS Supported, working Supported, working Supported, working Supported, working
    Microsoft Excel Integrated* in the OS Supported, working Supported, working Supported, but not working because connection is read only
    Error reported: S1000, “Operation must be an updatable query.”
    Microsoft SQL Server If not integrated in the OS ask vendor Supported, working Supported, working Supported, working Supported, working
    Microsoft Text Driver Integrated* in the OS Supported, working Not working Error Reported: IM002, “Data source name not found and no default driver specified.” Not working Error Reported: IM002, “Data source name not found and no default driver specified.” Not working Error Reported: IM002, “Data source name not found and no default driver specified.”
    MySQL Available at:
    www.mysql.com
    FileMaker Pro ** Available at:
    www.filemaker.com
    *On Windows 7 64bit systems, you need to run the 32bit ODBC manager (odbcad32.exe) to see the built in drivers, which are currently 32bit only.
    ** FileMaker Pro includes the driver needed to share your database as a data source. To use your FileMaker database file locally, FileMaker Pro must be running, and the database file opened and shared. To share your FileMaker database file as a data source over a network, use FileMaker Server Advanced.
    Macintosh
    On the Macintosh, there is no integrated ODBC manager. Suggestions include:
    Actual SQL Available at:
    www.actualtech.com
    Problem reported: data length restriction when writing to database
    Supported, working
    Actual Access Available at:
    www.actualtech.com
    Supported, working Not supported Not supported Not supported
    MySQL Available at:
    www.mysql.com
    FileMaker Pro * Available at:
    www.filemaker.com
    Edited by JimW
    • Like 2
      Report Article
    User Feedback
    Hey guys,
    how about PostgreSQL?
    We tried to connect a PostrgeSQL database by using ODBC w/o success.
    Is PostgreSQL a supported database?
    Greez, Alex
    Edited by Alexander Thiel
    Correction
    Share this comment
    Share on other sites
    It is not, no.
    • Like 1
    Share this comment
    Guest
    Add a comment...
      Only 75 emoji are allowed.
