  • Workflow and Performance Improvements for Vectorworks Spotlight 2020 in Service Pack 3
    JuanP
    Introduced in Vectorworks 2020, Schematic Views were a welcome improvement over plot and model views. But because of some deficiencies, you couldn’t hit the ground running. Label legends in Schematic Views did not display consistently. Schematic Views were updating every time the model was edited, slowing down your workflow. More visual context was needed to easily edit model objects while working in Schematic Views, and more visual feedback was required to properly snap lighting devices to rigging objects. Reengineering in version 2020 Service Pack 3 (SP3) has addressed these issues, bringing significant improvements to the performance and stability of Vectorworks Spotlight.
    Faster Schematic Views:
    It’s a common part of your workflow to make a series of edits to a lighting device. You frequently update the device, whether it be changing the channel, adding an accessory, or even repositioning the device on the truss. Prior to SP3, each of these individual edits caused the Schematic View to regenerate, disrupting your workflow while you waited. Now, Schematic Views have an Update Geometry button, similar to the Update button for viewports. Each time the model is edited, its Schematic View is outlined in red. When the edits are complete, you can update the Schematic Views once and get the results of all prior changes. This quickens the pace of all Schematic View operations because the view is not updated with every change.
    Correct label legends:
    In the initial release of Schematic Views, the schematic label legends did not always look right. This was the result of a few bugs that were introduced when converting from the 3D model object to the 2D Schematic View. In SP3, schematic label legends support all options, containers, right-reading labels, and non-rotating layouts. Any update to the 2D label legend in the model is applied automatically to the Schematic View.
    More context when editing model objects from the Schematic View:
    With a Schematic View selected, you can click the Properties button on the Object Info palette to edit the properties of the corresponding model object. The feedback from many of you indicated that more visual context was needed; you could not immediately see the object you were editing. For SP3, clicking the Properties button automatically selects and fits to the model object, making it visible and graying all other previously-shown objects. If the object supports sub-classes, your user settings are preserved. Now you will have more context while making changes in the Properties dialog for the selected model object.
    Improved load attachment:
    With the initial release of Vectorworks 2020, issues with auto positioning sometimes made it difficult to attach lights to rigging objects. When inserting lights, there was no visual feedback to indicate the light’s position on the snapped truss (unlike when dragging lights). Sometimes, Auto Position picked the wrong truss in 2D or didn’t find a truss in 3D. Major improvements to auto positioning have fixed these problems. An improved search algorithm makes it faster and easier to attach lights at the correct position, and the AutoConnect highlighting from Braceworks now provides interactive feedback when inserting lights. When lights are attached to a truss with a hanging angle, they now assume the more precise Z height of the truss.
    Greater stability of Vectorworks:
    The improvements in SP3 have made Vectorworks faster and more reliable, especially when working with large files. Changes related to Project Sharing have also enhanced the stability of Vectorworks.
    Performance improvements:
    Performance of the lighting device object has notably improved. Depending on the file, Refresh Instruments is up to 50% faster than in 2020 SP2 and up to 100% faster than in Vectorworks 2018. Moving multiple lighting devices in Vectorworks 2020 SP3 finishes in half the time or less than in Vectorworks 2020, Vectorworks 2019, or Vectorworks 2018. Similar results occur when duplicating multiple lighting devices, except when using the Paste command.
    The Schematic Views workflow in Vectorworks 2020 made plot and model views obsolete. Removing the obsolete functionality has further increased performance, especially for design layer viewports.
    We are seeing performance improvements with all file sizes. Larger files show significant increases in performance.
    File open times for ~1,000 lighting devices:
    2019                 53 seconds
    2020 SP2         26 seconds
    2020 SP3         16 seconds
    Creating Schematic Views:
    2020 SP2          40 seconds
    2020 SP3          20 seconds
    Changing the view of a Schematic View:
    2020 SP2          50 seconds
    2020 SP3          25 seconds
    Moving ~1000+ lighting devices:
    2020 SP2          5:00
    2020 SP3          16 seconds
    Duplicating ~1000+ lighting devices:
    2020 SP2          5:16
    2020 SP3          18 seconds
    The Vectorworks 2020 Service Pack 3 is available as a downloadable updater for all U.S. English-based versions of Vectorworks 2020, including Vectorworks Architect, Landmark, Spotlight, Designer, Fundamentals, Braceworks, ConnectCAD, and Vision. This Service Pack is available as a downloadable updater for all U.S. English-based versions of Vectorworks 2020. To install the Service Pack, please select "Check for Updates" from the Vectorworks menu (Mac) or Help menu (Windows). To find out more about this release, read the Vectorworks 2020 SP3 tech bulletin. Contact tech@vectorworks.net with any technical questions.
    Edited by JuanP
    • Like 2
      Report Article
    User Feedback
    Proceed with caution. I updated to SP3 and am crashing every few minutes. The same file and operations were working fine with SP2. Common crashes include moving and duplicating symbols, panning and zooming, refreshing viewports.
    How is SP3 running now?
    I haven't opened a file since my last gig in March. Some torturous version of SP2 was live then—and it was a giant bag of hurt. Just like SP1. And the original 2020 release. And the original 2019 release. And 2018. And 2017. And 2016. 2015… wait, is this a pattern?
    The video shows the pain of simply trying to dock my toolbars in late February. On one hand, I regularly had design assets move 50-100' without reason, become invisible or entirely disappear from my canvas. On the other, toolbars would sporadically transition from being neatly docked to a random scatter around my workspace. Thankfully, it was always difficult to get them re-docked and organized.
    I love paying a generous annual subscription for professional software that carries major bugs six months after release. Not that I need the primary design tool for my design business to be reliable. You know what they say… always trust your most important tasks to beta software. With Vectorworks, every release should be considered beta until at least SP4.
    Losing a day (or more) worth of work on every other project is a rite of passage, designed to create a sense of frustration-based camaraderie within the Vectorworks community. Does anyone else feel the love?
    SP3 is running quite well here. Have been doing al lot of training sessions on it and 1 actual real life project since the mayhem started. There is a thing here and there but I am happy with it now.
    Add a comment...
