Some users have reported red X's appearing in their Vectorworks UI. This is often caused by Kaspersky AV:
If you are encountering problems specifically with Kaspersky Antivirus, where you are seeing the following errors:
To correct this problem, highlight all of the components that have been removed and choose "Restore"
Then, click the Settings button:
Then, click "Settings" under "Threats and Exclusions"
Then click "Add" and browse to the Vectorworks 20XX folder (or whichever version of Vectorworks you are currently using), and select making sure to check the options to include subfolders.
Once you have done this, if you launch Vectorworks again and still encounter problems, you may need to remove Vectorworks and reinstall entirely:
http://kbase.vectorworks.net/questions/1105/Uninstalling+Vectorworks
Once you reinstall, the Trusted Location settings should remain, and you should be able to use Vectorworks normally.
Edited by JimW
Report Article
There are no comments to display.
