In some instances, you may import a SketchUp (.SKP) file that appears broken apart or exploded when viewed in Vectorworks:
This is often caused during import. To correct this, delete the faulty imported geometry, then import the .SKP file again. Under the SketchUp Import Settings, under Geometry Settings, make sure the method is set to "None":
Your import should then appear as expected:
Edited by JimW
- 1
Report Article
There are no comments to display.
