  • Sign in to follow this
    Accessing the menu commands without using keyboard shortcuts
    PVA - Jim
    1) Use the Workspace Editor to add the menu command to one or both of the context menus. You can then access the command with your mouse, from either the right click options of your mouse (on Windows) or the Control + click options (on Macintosh).
    2) Select Tools > Workspaces > Workspace Editor.
    3) Select Edit a copy of current workspace, in case you need to revert back to the original format of the edited workspace.
    4) By default, "Copy of" or "-copy" is added to the name of the workspace that you are editing. Enter another name if you wish.
    5) Click OK.
    6) In the Workspace Editor dialog box, make sure that the Menus tab is selected. In the right window, click the plus sign (Windows) or arrow (Macintosh) next to the context menu (Object Context in our example). This displays the commands currently in the menu.
    7) In the left window, click the plus sign (Windows) or arrow (Macintosh) next to All Menus. This displays all commands from all menus in Vectorworks.
    8) Select the command that you want to add to the context menu (Add Surface in our example). Drag it from the left window to the appropriate position in the menu in the right window. Add more commands if you like.
    9) Click OK to save the changes. Vectorworks automatically changes to the new workspace.
    10) When you right click (Windows) or Control + click (Macintosh) the mouse, the new command (Add Surface in our example) is now available in the context menu.
    Edited by JimW
      Report Article
    User Feedback
    There are no comments to display.
    Create an account or sign in to comment
    You need to be a member in order to leave a comment
    Create an account
    Sign up for a new account in our community. It's easy!
    Register a new account
    Sign in
    Already have an account? Sign in here.
    Sign In Now
